Spider Gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hawglet, Feb 18, 2001.
  1. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    I have an '84 K5 with 400 small block,700r4, and 3.73 gears running 33's. I was leaving work and I got in to it enough to break the tires loose. They caught before I was through the intersection and about 1/2 block later I felt a big BANG, felt like someone assholed me, I stopped cause I have a bed u-joint and figured that was what it was. It wasn't, I'm thinking that it is the spider gears, driving down the road it makes a real loud clunking sound. Of Course I took it out of action immedately. I going to pull the rear diff. cover off tomarrow afternoon to check it out.
    Thanks,
    Greg Gayman
    Hawglet
    Stovie
    hawglet@excite.com
  2. blazercrazy
    blazercrazy Registered Member
    Feb 18, 2001
    24
    (squinching with pain) good luck!
    Keep the rubber down [​IMG]
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The spider gears aren't spinning while the truck is going in a straight line. They're just along for the ride until differentiation is required. My guess is that you broke a tooth off of the ring gear. [​IMG] Very common failure mode with the 10 and 12 bolt rear ends.
