Spider gears?????
Discussion in 'The Garage' started by jram1484, Nov 29, 2005.
  1. jram1484
    jram1484 Registered Member
    Nov 13, 2005
    5
    Ft. Polk La.
    My buddy stripped out his spider gears the other day on his K5. He has converted to 3/4 ton axles and has a D44 4:10 in the front. The ?? is from what axles can I use the spider gears out of? Does the ratio matter? Can I use a 10b 1/2ton or what? I have three 1/2 ton 10b around. But don't have access to his front end because its his DD. So before I go through the work of taking the gears out of the ones around thet house I wanted to know will they fit.Thanks in advance for any help.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If its a d44 , it takes d44 . 10b will not fit .
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Just buy the correct internal kit...should be less than $100 bucks at a driveline shop.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I agree, just order an IPK.
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
  6. jram1484
    Nov 13, 2005
    5
    Ft. Polk La.
    thanks
    Hey thanks guys that is what I needed to know. preciaaaaattte it.
