spider gears
Discussion in 'The Garage' started by 87k10, Dec 2, 2005.
  1. 87k10
    87k10 Registered Member
    Sep 1, 2005
    31
    colorado
    how do i get them out? sorry for the dumb question
  2. 87k10
    Sep 1, 2005
    31
    colorado
    i know a lot of people here have welded rears, so ya wanna tell me how? :D
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Front or rear axle. Either way almost the same.
    Front,
    Remove the axle shafts
    Remove the bolt that holds the pin in place
    Remove the pin that holds the spiders in
    remove the spiders
    Rear.
    slide the axle shafts in
    Remove the C clips
    slide the axle shafts out
    remove the spiders
  4. 87k10
    Sep 1, 2005
    31
    colorado
    Rear.
    Remove the bolt that holds the pin in place: are you talking about the bolt on the front of the rear axle that goes on the pinion shaft?
  5. readymix
    May 30, 2004
    6,706
    26
    NO.
    Take teh diff cover off and rotate the carrier until you see a small bolt head. I think is is 5/16. It goes from the pass side towards the drivers side. Remove that and the pinion pin will slide right out
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Sounds like this is your first trip inside a diferential. If so, pick up a manual. As they saying goes, a picture is worth a 1000 words.
    That's all I've got to add since that old sea dog answred you already.
