Spindle Bearing Placement?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Aug 11, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    I noticed as i hammered in the new spindle bearings that there is a lot more room for the bearing to go into, dept wise i mean, than there is bearing, the spindle tapers about an 1 or two in, my question is do i get that bearing in there to the point where the spindle tapers or does it matter at all as long as the entire bearing is the spindle? Their warn hubs and a ten bolt axle
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I push mine down the same as they come stock. About 1/8" below the face, just enough to leave room for the seal to go over top of it.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sorry to highjack the post, but how do you get the old bearing out?
  4. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    i just took a piece of spare round tubing i had lying around and pounded it out with a hammer from the other end, it came out pretty easily
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is there really any reason to replace spindle bearings? I have never touched mine!
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have tried a brass drift and the bearing just brakes into pieces.
  7. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    ya the only reason i replaced them was because the actual spinning things inside the bearing, rollers i guess you could call them all fell out when i washed the inside of the spindle, i wouldnt replace something that wasnt broken /forums/images/graemlins/thumb.gif
  8. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    a 2 jaw puller works very nicely
