Spindle bolt torque?
Discussion in 'The Garage' started by toy4x4runner, Oct 6, 2005.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    the studs that hold the spindle on to the knuckle. what do you torque them guys down to? what's the Factory shop manual say? I replaced my studs from parts mike less than 1yr ago along with new nuts. Looks like in Nov I'll be switching over the the "big bearing" late model hub set up. so just wondering. thanks.
    -Jason
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I just tighten them by feel and they don't back off .
  3. bridgeguy
    bridgeguy Registered Member
    Mar 8, 2002
    90
    Oroville, Kalifornia
    Chilton calls out the following:
    Adjust the bearings by rotating the hub and torquing the inner adjusting nut to 50 ft. lbs., then loosening it and retorquing to 35 ft. lbs., still rotating the hub. Next, back the nut off 3/8 turn or less. Turn the nut to the nearest hole in the lockwasher. Install the outer locknut and torque to a minimum of 50 ft. lbs. through 1978 and 80 ft. lbs. for 1979 and later models. There should be 0.001-0.010 in. bearing end play. This can be measured with a dial indicator.
    Hope this is what you're looking for.
  4. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    I'm looking for the torque value for the studs that hold the spindle itself onto the knuckle. Not the wheel bearing nut. Although I think you posted that for me the other day... i wrote it down and saved it, thanks.
  5. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    The Haynes books say 20 foot pounds but that is wrong. My GM factory service manual says 60 foot pounds. I usually take them to 50, with locktite.
  6. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    60?? that sounds like a lot for such a small bolt. I think 20, or 30 sounds about right??? :confused:
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    My GM shop manuel say 45lbs/ft of torque.
    but the bigger problem is where to get the locking nuts ?
    Remeber there is only six holding the spindle to the knuckle
    this is a saftey item, you don't what too come lose or fail !
  8. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    What size and grade are they. I can run a calculation.
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I just tighten them till they're tight.
  10. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    Not sure what grade they are. their not really that large.... kinda supprised me, figured they have some nice 1/2" bolts or somin. Right now i have them torqued to 30lb/ft with all new hardware. I think they're 3/8" stud, about 1" long roughly. Grade... um... it's not goldish looking like grade 8, so i'm thinking stronger like Rod bolts or somin. ARP style... which is 8+ I think.
  11. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    did some searching around. measured the thickness of the new locking nuts. the studs are 3/8"-24 fine thread. I'm guessing Grade 8. did the calculation and it says 41.2 recomended and 54.9 max. (Lb/Ft). For grade 5, says 29.2-38.9 lb/ft. They really do look like grade 8 to me, and if the GM FSM is saying 45 it's b/c the self locking nuts adds more drag. so if you're meter clicks at 41 lb/ft then then it's probly at only 35. So I'm gonna torque mine to 45 Lb/ft with no lube, dry and clean with new lock nuts that I got from parts mike. I'd like to get my torque wrench calibrated before this job too.
  12. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    IIRC 45 was the number i torqued to
  13. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Yep, 45 with some thread locker.
  14. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    Wonder if the thread locker is neccesary, or even advisable? :confused: b/c it acts as a lube on the threads i think. and what strength thread locker would one use? This is just one area worth the time and effort. b/c those little 6 bolts are holding our front wheels on :eek1: .
