Spindle compatability
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Oct 21, 2000.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Called Inland truck parts, they said all they have is a 87 GM spindle for a corp 10 bolt. Do you guys know if that will be the same spindle for a 90 10 bolt??
    Don't you buy no ugly truck!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I dont think they changed anything on the 10 bolts other than the splines on the axleshafts.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes, there all the same, becuse Dana made them for the 10 Bolt LOL(NOT)
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I have since found some. Now all I need to know is what are the torque specs for the 6 nuts that hold these spindles on. 75lb?? P.S. I hate packing bearings by hand.
  5. I have that info at the house,when I get home I'll post it Brandon.I don't know about spindle compatability though.
    Good Luck
    IF IT AINT BIG IT AINT BAD!!!!!!
  6. Executioner
    Feb 22, 2000
    1,530
    45lbs./ft.
    Please post the part number of the spindles that you got
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    OOps!! I went ahead and torqued'em to 75lbs. Ya'll think this is to much. So I back off and re-torque or leave them the way they are?
    P.S. Didn't have a part #. Got them from 2 different junk yards. And I dont see any #'s stamped on them anywhere. ALso I need to get that damn needle bearing outta there. Any ideas?
  8. Executioner
    Feb 22, 2000
    1,530
    Just courous how do you know what spindles you got ?
    Do you know what happens when you strecth a bolt/nut ? Clue it not like recovery strap.
    Good luck
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    A recovery strap [​IMG]that's a good one[​IMG]. Any way, to get the needle bearing out, since you're replacing it anyway right?, Big hammer and screwdriver[​IMG]!
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  10. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I took the old wheel bearings, spindle nuts, and axle and made sure they where the same size and all. Plus I saw both front ends that they came off of. They where GM 10 bolts same as mine. They are already on adn fit just fine. Had to take a little rust off one though. Now it looks like my freaking steering knuckle joints are worn. I still have vertical play with both wheels. :(
    Anybody changed these out at home before???
