spindle nut
Discussion in 'The Garage' started by AJBK588, Jan 16, 2007.
  1. AJBK588
    AJBK588 Registered Member
    May 19, 2005
    12
    IL
    how many ft/lbs should the front spindle nuts be torqued to?
  2. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Kinda need to know what you're working on...
    Dana 60 -> 65 Ft/Lbs
    Manny
  3. AJBK588
    May 19, 2005
    12
    IL
    yah sorry not thinking it is a k5 88 10 bolt 8.5
  4. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Ah, okay, lets see.....
    88 K5 10Bolt......88K5 10Bolt......88K5 10Bolt.....hmmmmm.....
    See below
    Manny
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Outer spindle nut on an '88 is spec'd at around 160 ft/lbs. :shocked: It's critical if the factory auto-locing hubs are still in use...
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Yep, dana 60's get much less torque than half ton stuff.
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    If its the inner spindle nut your working on then it should be torqued to 50 ft/lbs. Then backed off, then re-torqued to 35 ft lbs, then backed off 3/8 of a turn.
    The outer nut is somewhere between 160-180 ft lbs.
    -Harrison
