spindle vs tradional IFS lift kifs
Discussion in '1992-Present Chevy & GMC models' started by thezentree, May 4, 2004.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    is there any difference in strength between spindle lift kits and traditional kits with upper a-arm drop brackets? clicky
    the splindle kits look easier to install, but if theyre weaker, then f**k that
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    The kit looks almost identical to the new H2 lift kits. They don't seem too bad as far as IFS goes. The lateral compression arms look as if they would really help out when lateral force is at work on the front end (like whem climbing a large rock or embancment.)
  3. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    282
    156
    Gustine
    I think it is a better set-up because the whole suspension hasn't been relocated, only the bottom bracket and in the kit you've linked to, the bottom bracket is a one piece cradle. This should no worse than stock.
  4. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    Looks like a nice set up Id like to see how that holds up on the trail.
