Spindle washer/spacers???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Emmettology 101, Dec 6, 2001.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    My friend and I were tearing apart that 87 Jimmy I borught home from NJ the other day and were putting in a new ball joint... When we yanking the spindle off, there was a thin washer/spacer behind it. I never seen this before.. Has anyone else??? This washer/spacer goes between the spindle and the knuckle......
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Its a camber adjustment shim.
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I didn't mic it, but it looked like all the same thickness....
    Mike
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    There should only be a couple thou difference to make up a degree or two in camber...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    True, i should have mic'd it..... But I have had close to 10+ of these axles apart and this is the first spacer/washer i have come across.. Are these only on the newer axles?
    Mike
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I've only heard of them...never actually saw one.
    Rene
  7. 89OKIE
    89OKIE Registered Member
    Aug 16, 2001
    11
    Check out your Haynes Book, they mention a thrust washer which is bronze, that goes up against the knuckle. My 89' didn't have one when I changed out the upper and lower ball joints. Good Luck!
