Spindles
Discussion in 'The Garage' started by MontanaLifted, Apr 9, 2003.
  1. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    I need a spindle for a Dana 60 3/4 ton
    Please anyone???
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    They should be easy enough to find in the parts yard. Have you tried posting it up in the WANTED section? If you cant find one I know I can get one from my area.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Wasn't aware that they made 3/4 ton D60's. They made the D44 in 3/4 ton, and those are easy to come by. The spindles off a D44 and 10 bolt will interchange so you can double you odds. Unless it is off a pre-76ish with the large external hubs.
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Think he is talking about the rear D60.
  5. MontanaLifted
    Aug 27, 2002
    171
    No, no,
    I have a Dana 60 up front and a 14FF out back.
    The Dana 60 is set up 8lug and has 3/4 ton u-joints on the axle shafts.
    I believe Dana 60's came in either 3/4 ton or 1 ton just like the 14 bolt Corporate. On the 14 bolt if it's full floating (outerbearings) then it's a 1 ton.
    Yeah or neah?
    /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    As far as I have ever heard is D60's only came in 77 and up 1 ton trucks. The 3/4 ton version from Dana is the D44. I would check to make sure you have a D60. D60's are much more rare then the D44's. A D60 should only have 3 ubolts that hold the axle on. The passenger side should have 2 bolts that replace the 4th ubolt. Also there is a 60 cast into the pumpkin at the lower right (as you look at the cover) of the diff cover. The ujoints and axleshafts are also much larger then the D44.
    If you have a D44 as I mentioned above you can use the spindle off of a 10 bolt or D44 as long as the axle is post 76.
    A pre 76 D44 might look similar to a D60 because of the larger external hubs.
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    A little clarification on the 14 bolt issue:
    14 bolt FF: this is the full floating design with the big hubs sticking out of the wheels. It can be found in 3/4 tons and 1 tons....same axle, just different spring plate locations and bigger brakes on the 1 ton version.
    14 bolt SF: this started showing up in 3/4 tons...towards the late 80's it's no longer a sure thing if a 3/4 ton truck is going to have the FF or SF 14 bolt.
    And, as far as I know, dana 60's are purely one ton axles and won't be found in anything of lesser payload.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    There's only one GM Dana 60, and its 1-ton equipment. The only slight variations are the 77-79 shafts have a "necked-down" portion seen here: pic and the '91 hubs are completely cylindrical, (ala Dodge) whereas the rest have a taper to them.
    Regardless, the spindles themselves are the same on all 77-91 GM Dana 60's, which are also the same as '75-93 Dodge Dana 60's. SRW or DRW doesn't matter.
    Hope that helps. /forums/images/graemlins/wink.gif
  9. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    do you have pics of what you are trying to identify and replace? i think it would be helpful at this point.
  10. MontanaLifted
    Aug 27, 2002
    171
    OK Hoss,
    This is what I have. By the way never trust someones word for it always check and run your numbers so you don't look like a dumbass!
    Lookin at the diff cover;
    Lower right 44-8F
    Top right (numbers are upside down and in two lines)
    38335 (like that)
    Bolt tag 45-11
    4.09
    Any info would be great!!!
    Thanks guys
  11. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Lower right 44-8F
    This is a Dana 44 /forums/images/graemlins/thumb.gif If it was a 60 would have had 60-F in that spot.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    OK Hoss,
    Lower right 44-8F
    38335 (like that)
    Bolt tag 45-11
    4.09
    Thanks guys
    Yep, sorry to burst your bubble....thats a D44 front, not a D60. /forums/images/graemlins/frown.gif
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Now the question is does it have internal or external locking hubs? If it has internals (77-91) you can use any D44 or 10 bolt spindle. If it is pre 77 with external hubs then you need a different spindle only from the pre 77 D44's.
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Exactly!!! /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  15. MontanaLifted
    Aug 27, 2002
    171
    ignorance is sometimes bliss but I feel like a retard.
    What exactly do you mean by "external hubs" and "internal hubs"?
    Are you talking about the lockouts?
    (I should have emptied out my digital camera)
    aarrrggghhhh---I'm pulling hair out.
    Thanks for the help fellas. Please keep schooling me. Obviously axles are not my strong point.
    Does anyone have a website for Dana Spicer stuff so that I can research more?
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  17. MontanaLifted
    Aug 27, 2002
    171
    No not at all, aside from the Warn brand name.
    My hubs are gigantic. Instead of being cylindrical like the ones in that article mine are more of a cone shape with the excess material shaved off the sides.
  18. MontanaLifted
    Aug 27, 2002
    171
    To answer your question now Hoss,
    I have the Warn premium external hubs.
    Thanks to the Warn hub post here in the garage!
