Spinoff : REBEL RUN TO DO LIST.
Discussion in 'The Garage' started by FL84K5, Sep 5, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Lets here yours, here is mine.
    4 Inch Lift
    Install ORD Zero Rates
    Buy Receiver Hitch
    Pintle and Pintle Adapter for above reciever hitch
    Buy and install front tow hooks
    37" Swampers SSR's
    Alignment
    New Wiper Motor
    Fix Reverse Lights
    Devise a better way to anchor tach to dash pad
    Install battery hold down
    Get tow strap
    Spare Plugs
    Spare Wire
    Spare U-Joints
    Spare Misc. Nuts and Bolts
    Service front diff, tranny and t-case
    Cut Front fenders
    Paint stock rally wheels gloss black
    Theres mine, lets see yours.
    FL84K5
  2. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    Re: Spinoff : FLORIDA RUN TO DO LIST.
    Hummm, to do list?
    1. Get Directions
    2. See number one
  3. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    I dont know if I will make it since I work 60-80 hours a week and times running out. Anyway here goes...
    Install new cam and heads
    install 5.13 gears
    install detroit in 14FF
    install power-lok in D44
    finish front bumper and install winch
    trim fenders
    move front axle forward 2.5"
    move rear axle back 2"
    after all that then I'll tackle the TBI swap. Har!
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Lets see...
    1 finish brakes on new axles
    2 get front gears and get them in
    3 get axles swapped
    4 get rims swapped
    5 install Hydro Boost
    6 shackles
    7 maybe lift a few more inches
    8 change windshield
    9 get wipers so they are in the DOWN position when off. LOL!
    10 Oh yeah new shaft for the rear
    11 try to strip out interior
    12 make an attempt to get 1/2 doors done
    13 make a front receiver
    14 maybe swaybar discos
    15 adjust valves
    16 change cooloant to green type, RED COOLANT SUX!
    17 install 2nd battery tray and at least have a back up battery on hand
    18 try to get atleast front bumper built
    19 get my CB working properly or get another
    20 change oil, lube EVERYTHING
    21 build front to back vent tube for axles Tcase and tranny
    22 try to get a chance to find/fix oil leak
    23 clearance front shaft
    This is just a start. Ill add more to it as I think of it.
    THEN I need to get stuff to take.
    1 get another first aid kit
    2 collect up all my straps
    3 get a few extra ujoints
    4 TOOLS
    5 tent
    6 clevis
    7 at least 1 more fire extinguisher, preferably 2 already have 1
    Ill never get all this done!
  5. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Load K5 on trailer
    Hook Diesel to trailer
    Drive due south on I-95!!! /forums/images/icons/grin.gif /forums/images/icons/grin.gif
    Of course, this doesnt fixing any Dixie breakage
    rob
  6. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Load K5 on trailer
    [/ QUOTE ] You suck Rob! /forums/images/icons/grin.gif
    Ill never get all that stuff done to mine. I have some things that WILL be done but the majority of it is short term plans that if I can get the done great. If not Oh well.
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Jason, now you need to add
    1 hope Blazer doesnt total
    2 get Blazer back from body shop
    3 THEN start on the above list!
    /forums/images/icons/shocked.gif /forums/images/icons/mad.gif /forums/images/icons/crazy.gif /forums/images/icons/wink.gif /forums/images/icons/grin.gif
  8. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Update to my list!!!!!
    1 hope Blazer dosn't total
    3 pray the the items I have for sale sell, or I won't be doing any of the things on my original list. /forums/images/icons/frown.gif
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK I have gotten done or got ready to swap the following.
    Front shackles
    Axles and brakes are coming along
    Found oil leak (bad fuel pump, had to change it cuz it was dumping gas into oil, and it turned out to be my leak too. /forums/images/icons/grin.gif )
    Changed oil but Ill do that again before I leave
    Hydro Boost is cleaned and ready to install
    Forget the 1/2 doors I wont get to them
    Will prob just remove sway bar rather than use discos
    2 battery tray and batter is installed, not wired yet but its there.
    Working on lifting a few more inches (2) by way of shackle flip and traction lifts.
    May have a new CB
    So I guess Im making progress......... /forums/images/icons/smirk.gif
  10. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    List update /forums/images/icons/laugh.gif
    Got the battery secured
    Got a tow strap
    Found a toolbox to bolt down in the back
    Found out the the insuance company isn't going to total the Blazer, so I'm just waiting on it to get fixed.
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Shackle flip is almost done and ready to install
    Front reciever bumper is coming along, may end up being just a reciever under the stock bumper for now but it will be in.
    Getting steel for Traction lift this week
    Have rear shock relocation mostly done just waiting to install
    May get Ford front shock towers
    Ill fix the wipers when I do the Hydro, Ill already be under the hood (or have it off) so Ill do it while Im back there.
    Working on mounting extra tranny cooler and PS cooler
    If I find the time I may work on installing a YORK compresser. Found a brandey new one sitting on the shelf at the shop. /forums/images/icons/wink.gif
    Gettin there! /forums/images/icons/grin.gif
  12. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    1.put in tranny and transfer case(correctly
    2.install new carb and intake
    3.figure out what to do with stripped out sterring wheel bolt??? /forums/images/icons/confused.gif
    4.weld rear end
    5.lock front end(maybe with reds loc-right /forums/images/icons/grin.gif )
    6.fix and patch holes in floor
    7.cut front fenders in front for more room to flex
    8.bleed brakes /forums/images/icons/shocked.gif (that should be #1)
    9.rebuild front and rear driveshafts
    10.wire up new kc's
    11.new net doors(see post)
    12.get a small shackle for front bumper for towstrap
    13.get 6 or 7 ujoints for trip /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif
    14.make sure I can drive it on interstate /forums/images/icons/blush.gif
    15.get a JOB /forums/images/icons/mad.gif
    16.WINCH
    17.insurance
    18.expired tag /forums/images/icons/frown.gif /forums/images/icons/shocked.gif /forums/images/icons/mad.gif get that renewed
    19.buy new cooler
    20.pray to god /forums/images/icons/grin.gif
  13. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
