spiral fluting urethane bushings, pics
Discussion in 'The Garage' started by rdn2blazer, Dec 8, 2006.
  1. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I do this to every bushing I install. it helps keep the spring ID from rusting and you dont have to take apart the bushings to grease the OD. these are fluted from factory on the ID but as far as I know you cant buy them fluted on the OD.
    I use a used cutoff wheel that is of a fairly small diameter, you can get closer to the shoulder that way. also because its worn the edge is radiused not a square edge like a new cut off wheel has.
    first I cut a slot from the ID flutes to the OD of the bushings of the small dia. ofcourse. then I radially cut a slot til I allmost hit the shoulder. I dont go very deep at all, maybe a 1/16.
    these bushings are the energy suspension bushings out of some 4 in. TC springs for my blazer.
    some people say they should be installed dry and the grease is so the steel bushing gets lubed and spins, but I think it should see grease everywhere. just my .02 cents.
  2. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    Cool.
    Thanks for the tip. I'll have to try that out when I swap to 52's in a few weeks.
  3. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Now that's a bum deal!! I expected you to be chucking them up in the dividing head and milling the grooves in them! LOL
    JImbo
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Cool I had lots of poeple tell me that did nothing for the bushings I used to do it to my sami bushings, sure seemed to work for me
  5. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    do you see the precision job I did by hand?? I dont need no stinking dividing head!! thats a 3 axis cnc move by hand pal :D :haha: :p:
  6. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    rdn2blazer, you mentioned seeing grease on the bushing. Are you using greaseable bushings? If so what is the exact size of the hole through the bolt? I am considering using greasable bolts for an applacation like this and was concerned about the shear load on the bolt, since it has been core drilled.(I understand the bolts are grd 8, and the center isnt what you would call hardened, but it is still part of the structure)
  7. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    without taking the zerk out I could not tell you. I do know its a tiny hole though. the cross hole that lets the grease into the bushings is probably no more then say 45 to 55, maybe 60 thousands max. would have to actually chect it. I have a pin gage set, it starts at .061, if that does not fit its obviously smaller.
  8. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    refresh, for those who missed this incredibly brilliant idea :D
  9. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    alot of new people here so Im bringing this back one more time, ya know, cause I care. :D
  10. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    Another refresher for the new noobs. Arn't I kind. :D
  11. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    I don't know how I missed the first two times, and count me in expecting a dividing head.
  12. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I will tell you the same thing I told the last guy....
    Quote:
    Do you see the precision job I did by hand?? I dont need no stinking dividing head!! thats a 3 axis cnc move by hand pal :D :haha: :p:
    End Quote. :p::p::p: :haha:
  13. MojaveK5
    MojaveK5 1/2 ton status Premium Member
    Sep 25, 2007
    672
    Hesperia, Ca
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Braggart. :rolleyes::D
  15. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    Is there such thing as a tech whore?
    J/K, saved for future reference. :waytogo:
  16. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I know, what a jerk huh :D, I am quite proud of this for sure lol! I'm proud of my tech whoreing man!! you know you think its a bad ass idea though. you know your gonna do it on your next bushing install, you know you love it don't you, come on, oh yeah, tell me you............oh wait, I......
    Sorry, I got carried away a little lol!! :haha: :p: :p: :p:
  17. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Reviving thread. This is an excellent modification to standard urethane bushings. For those running ORD disconnects, they tend to run dry after a while and seize up. I've drilled the body for a zerk fitting and fluted the bushings with a carbide bur. No more problems with seizure.
  18. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    I have been here since '03. First time I have ever saw this thread. Good idea.
  19. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    Your NOT viewing CK5 enough man, get with the program :D :p:
  20. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    His truck runs..... he goes wheeling :D:doah:
