Splash guards
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Mar 13, 2000.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    does anyone have any ideas on how to keep mud and water out of my engine compartment?? everytime, or some of the time, i go mudding, water and/or mud gets up under the hood. i know this isn't good, but if someone could give me ideas what to do, i would be much pleased. thanks :)
    alex
    "What me get stuck? NEVER!!"(Famous last words)
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    If you have a gap in your fender well that allows you to see the engine then you can go to your local HWare store
    and buy some thick rubber gasket material and custome make a shield. I did this and it works great!! I used a rivit gun to mount it to the sheet metal.
    Mud use to get on top of my air cleaner and everwere else now it stays ALLOT cleaner.
    Hope this helps
    Burt4x4
    Rock ON!
  3. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    The Chevy line of trucks in the 70's originally had a flap that goes between the inner fender and the frame rail. If you go to the junkyard you can probably find a pickup or Blazer with a set still on it.
    David 75K5
    [​IMG]http://www.renschler.org/~goldrush
