spline count th350
Discussion in 'The Garage' started by balls of fire, Jun 14, 2003.
  1. balls of fire
    balls of fire Registered Member
    Dec 29, 2002
    66
    Round Rock, Texas
    Does any one know the spline count of a turbo 350 on the out put shaft. It is on a 203 /forums/images/graemlins/confused.gif
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    turbo 350s and 700r4s have the 27 spline count
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    4x4k20 is correct
  4. balls of fire
    Dec 29, 2002
    66
    Round Rock, Texas
    I have been told that the 700's out put shaft is longer can you have it cut down? And if so is their enough splines left?
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Whatever you do do not cut the shaft shorter there is not enough room for engagement. You need to install the AA shaft if you want to swap to the 700R4 or use a spacer.
