spline count??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, May 15, 2002.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    I would like to know the spline count on a 1987 K-5 Blazer
    with a 350ci and a stock 700r4? What would be the number of splines.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    What FOR??????? Drive Shaft? Axle? Torque convertor? output shaft?? ??? ????
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Well if you are talking axles they would 28 spline......
  4. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    i need a new transmission for my blazer a 700r4 what would be the spline count
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    700R-4 is a 27 spline output...
    Rene
  6. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Torque convertor should be a 30 tooth spline. If you are buying a new 700r4 I recomend you get a new torque convertor. If not cleaned out properly your old torque convertor may be filled with particles and metal shavings. Which may cause your new tranny to fail. Also clean out the cooler good.
  7. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Thought the output changed to 30 spline in 87....???
  8. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The only thing I recall where the spline count changed to 30 spline was the 89 and newer 10 bolt diff's...they went from 28 to 30 spline that year.
    Rene
