Spline count
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suffergauge, Aug 7, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    On the rear yoke of the NP203, what spline count was for what engine? I believe there are 10, 27, & 32 spline output shafts right? Which is for which motor? I need to replace the yoke on a 79 K5 and don't belive it is the stock set-up.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    10, 27 & 32 spline counts are on the tranny output shafts and the t-case input shafts.
    10 spline = 465 tranny
    27 spline = 350 & 700R4 tranny (and 4L60E)
    32 spline = 400 tranny (and 4L80E) (and also '81 & newer 465 tranny)
  3. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    What about the output shaft of the tcase? Is there a difference? It is a 350/th350/np203 combo. I need to replace the rear yoke... that's what all the questions are about.
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Did you ever get an answer to this?
    I know this is an old post, but it's proof I tried searching before asking.
    Can anybody tell my how many splines are there in the rear output yoke of my 1979 NP203, which is behind a TH350?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    On GMs, I think all 203/205 cases used a 32 spline rear output. Front output is typically a 10 spline, but 30 exists. The Ford and Doges were available with 32 spline front outputs that will swap in. I don't know about the others...
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I will be working on mine this week end so if you don't get answers by then I will have:
    203, 205 and 208 numbers for both rear and front output spline counts.
    /forums/images/graemlins/thumb.gif
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Rear outputs of the 203 and 205 are 32 spline and the yokes are interchangeable. Front outputs are 10 or 30 spline for the 205 and I believe the same for the 203 but not positive.
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I know the 203 and 205 front 30spline are interchangeable, and I don't recall seeing any 10spline 203.
    Now I will be checking the 208 and we will have all the numbers.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    10 spline front 203 exist for the 465 203 70's 3/4 tons and 1 tons with 465
    apparently 81-up 208 with 465 are 32 spline input ?
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Are you talking input shaft or front output?
    I actually had a 203 behind the 465 but never checked it, now I sold it.
    I probably should ask him to check it out.
