Splitfire plugs, do they work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Nov 6, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Has anybody tried the splitfire plugs, do they actually work? After cleaning and adjusting my q-jet it still smells like gas out of the exhaust, I was thinking a better spark might help burn the gas and reduce the smell. /forums/images/graemlins/crazy.gif
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    If your ignition system is weak or your timing is off then they will help.
    You will eventually need to fix your ignition system and timing anyways. Save the money and fix your ignition system.
    http://www.73-87.com/
    Scroll down until you see IGNITION:
    Good luck.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have tried them and I heard the same from many sources:
    On high output , high revving engines, they rock, on slow going idling 4x4 they suck.
    I use the Champion Truck series and I am very pleased with them. they last a long time and they burn great.
  4. cityfarmer2
    cityfarmer2 Guest
    I have all of the above and kinda like them........ /forums/images/graemlins/k5.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Check your ignition system, and make sure the carb is adjusted propperly. You might want to run a hotter plug. I just can't justifie the price for the split fires. /forums/images/graemlins/eek.gif
  6. bajaviking
    Apr 10, 2002
    752
    Baja
    Can you recommend a hotter plug, I usually just ask for plugs for an 86 K5 and use what they give. Also, for a hotter plug what kind of opening do you recommend. /forums/images/graemlins/1zhelp.gif
  7. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    i got a free set from a herculiner rebate. they seem to work like any other plug, i really cant tell the difference. i dont think i would pay more for them though.
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    It is a gimmick. The spark can only travel to one part of the electrode at a time. You don't get two arcs like they want you to think.
    Find me a serious race team that actually uses them...
  9. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    My 350 runs smooth with "rapid fire" plugs, never had a problem with em, and the number on the plug is easy to remember, "1"
    Matt
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    yeah sure they work.. there a spark plug aint they?
    no, there not worth it at all...
    I had them you want them? just shipping...
