Spool installation
Discussion in 'The Garage' started by ramses, Jul 26, 2006.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    I think im gonna put a spool in my 60, is it very hard to install one? I have to change the ring and pinion anyway, what else is involved in installing a spool?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    for a full spool its just like setting up any other diff
  3. ramses
    Jul 2, 2004
    238
    West Virginia
    Can anyone go into detail? I guess a spool would eliminate the spider gears?
  4. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    This is a full spool. Mini spools replace the spiders I believe, and you reuse your differential casing.
    Basically pull out your diff. and put this back in it's place. Axle splines go in each side and the ring gear bolts on. Then it is just set up like normal. I got lucky as I was putting the same ring gear back in and all it took was turning the collars a little to get a good pattern. My first time putting gears in so I just basically watched my buddy do it so I am not much help on the proper set up techniques.
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You said that you are going to change the ring and pinion, but need to know how to install a spool.......?
    I would be more concerned about getting the gears right.
  6. ramses
    Jul 2, 2004
    238
    West Virginia
    Well ive done ring and pinions before but ive never installed a spool so I just wanted to see what I was getting into if I go that route. I unsderstand how a spool works but not a mini spool, I dont plan on ever using one but I would like to know how they work. So basically I just bolt the ring gear to the spool and the axles go in it and it eliminates the carrier and spider gears all together? I didnt know if you still needed to put the carrier in or not, I guess that wouldnt really make sense though.
