Spools oh spools
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Aug 23, 2001.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i was wondering if anybody was running spools front and rear? i want to with a 14FF. but i know it would be best to have hubs in the back...
    so my questions are, Anyone with dual spools?
    and, anyone seen a Hub kit for a 14bFF?
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't put them in anything except my lawnmower.
    Tim
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I know two guys with them in the rear, and they say that the spools really don't show up on the street except in tight turns.
    Lift It, Lock It, LIVE IT!!!
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    They don't make a spool for a 14 bolt...so AFAIK your choices are open, gov-lock, Detroit or welded. My 14 bolt has been welded for the last 13,000 miles. My Jimmy is a daily driver and weekend wheeler...other than tight parking lots and a bit of understeer its pretty seamless. I'd prolly stick with a detroit up front though...
    Rene
  5. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    The 14bolt in my 79K10 runs a Detroit &amp; The 60ff in my 68K20 will have a spool in it the next time I tear it apart.
    Joe
    79K10
    68K20
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I also have a welded diff (acts the same as a spool) in my 14 bolt FF. The truck doesn't get driven on a daily basis but on the road you really do not notice it all (yet to see snow and ice yet, but I'm not worried). You get a little tire chirp in parking lots and pulling out onto the street sometimes, but personally it does not bother me.
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Lawn mowers run open diffs to avoid tearing up the grass.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i have wanted to weld my diffs on my blazer for a long time. thing is i know a spool is stronger. and more reliable. if i do decide to weld them my only question is, can i do it with the carrier in the housing? i know i would have to be carefull not to hit the housing but will the heat warp anything? or deteriate the bearings. i know i would need to pull the shafts out....
    but anything else?
    Grant
  9. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    I welded the side gears to the carrier, ran about a 1 inch weld, went to the other side did same, rotated the carrier did the same procedure again until I had weld all I could get too.
    Make damn sure you get all the spatter and flux chunks out of there....I ran mine for about 2 hours drained it and put in fresh oil.....(also cleaned the whole inside housing with brake cleaner before I started)...check and make sure you have no gas leaks DUH!! stranger things have happened and gasoline isn't very forgiving.
    Veni Sancte Spiritus
    Da Pacem Cordium
    White Knight
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can also take the spiders out, weld them up, and stick them back in. Than if you deside you don't like it you could go to a detroit. I thinke tRusty has them done this way....I think I will also do mine this way as soon as I get a 14FF.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Yup, thats what I did to my 14 bolt. roughly 13,000 street miles and about 8 or 9 wheelin trips with no problems.
    Rene
