Spools vs. Mini-Spools vs. Lockers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Sep 27, 2001.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Can anyone out there go over the distinct differences/advantages/disadvantages of Spools, Mini-Spools, and Lockers? Also, how much should you be willing to dish out for each?
    Thanks All
    "Blazerism: When the Blazer is your God."
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    A spool is a complete carier, and a mini-spool slips in where you put it in the stock open carier. Using a spool requires you to use c-clip eliminators whick leak like crazy and are only meant for drag racing. A mini spool doesn require anything special. You just remove the spider gears and put in place. You dont even have to reset the back lash on the gears. A locker is a complete carier so you have to reset the backlash. You can use c clips with them. Your other option would be a slip in locker like lock rite. It is just like the mini spool, all you have to do is remove the spider gears and slip in. As for price most full spools are $200-$250, mini spool $100-$125, locker $525-$550, and a lock rite locker $275-$325. The advantages about a spool or mini spool is that both tires are permanetly locked together so you dont have to worry about it not working. The disadvantage is they are always locked together, so you have to get use to driving it around. The advantage is a locker engages and disengages. It will diengage around a corner if you are not in the gas too hard. The bad part is it has whats called a weave. It will engage and disengage around a curve making the rear ens move around. The other disatvange is the price. Your best bet is use a locker in the front and a mini spool in the rear. Thats what I am doing in my Jimmy right now. BTW your tires will wear more with any of them. They wear the same with a locker as a spool. I know alot of people that drive around on the street with a spool in their race car and have no problem.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Thanks DesertDueler, one more question though: How does the performance and strength and such compare between a Spool and a Mini-Spool? And with a Mini-Spool, is that something that most people could install themselves, or is that something that requires technical knowledge of gears?
  4. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    spool is stronger, mini spool is as strong as the origonal case. mini spool is a no brainer install in most axles. what axles do you have?
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    For a selection of spools and lockers, check out these sites:
    www.ring-pinion.com
    pugsley.alloffroad.com
  6. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I'm running a completely factory 12-Bolt with Gov-Lock... is that going to have an effect on the installation of the mini-spool? Also, what companies make a good mini-spools for chevy ends, and how do the prices range?
  7. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I put a mini spool in my front 10 bolt, don't have it together yet, so I can't say how good. I have manual lockouts, so I can freewheel on the pavement. the mini spool goes in the carrier, replacing the spider gears, and the axles go into the splined mini spool and are locked together
