Spray Can Special Advice Needed
Discussion in 'The Garage' started by Polaris, Aug 4, 2002.
  1. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    I know this is a pretty dumb question but I'd sure like to help my old man out. We started painting his K20 today, in military camo fashion. It is turning out alright but the thing is, it *looks* sprayed out of a can. You can see swirly looking marks and some of the olive drab cans sprayed this horrible looking green while some were nice. I can take pics in the morning if someone would like to see. Any tips on getting a more even spray from a can? Is a paintbrush job a better way to go? This evening we went over the the National Guard Armory and checked out their paint jobs /forums/images/icons/laugh.gif . Nice Sunday drivin' with the kids... you could see overspray between colors but it didn't look swirly within the color. Any advice appreciated. Hub was going to get a projector to project the pattern on the truck just to make sure and do a good job, but didn't get ahold of the thing. Point being, I think he wants it to look like a "good" camo job.
  2. Grim-Reaper
    7,385
    Atlanta
    They used a propper gun that put out a fan of paint about 10 times the width of a rattle can. If it were a regular paint job where you wanted it shinny it is almost cheaper to buy a cheap $50 gun and a gallon of automotive paint and get 100 times better results. Problem is getting camo paint is not easy. Not enough demand.
    Paint shoudl not be done in a circulalr pattern. It should pe done in a line stepping down on every pass. then it will come out a little more even.
  3. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Shake the cans- a lot. Shake them for about 5 minutes before you start, then stop about once every minute and shake it some more. You have to keep it mixed really well. Also, clean the tip pretty often to keep it from clogging up and squirting out globs.
  4. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    You're local parts store should sell a handle for cans that attaches and gives a better spray and helps on the finger. Makes it like a spray gun. Go back and forth, and definatly take your time! do light coats and work to the heavier ones. remember you can touch up and redo easily.
    Good luck
    Chris
  5. ratpack7
    ratpack7 Guest
    You have to take your time and do acouple coats. If you go side to side with a spray can you will get zebra stripes.
  6. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    what if you do mess up and get a run what is the best way to fix that? wait till it drys and resand...just guessing
  7. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    When painting w/ spray cans at least, you can wipe the run with a lint-free rag as soon as it occurs, and then wait a couple of minutes and go back over the area. Works for me.
    John
