Spray on Liner from a can
Discussion in 'The Garage' started by sublmnl1990, Nov 16, 2004.
  1. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    I was in Wal-Mart the other day and in the automotive section they had spray on bed liner in a spray paint size can. Has anybody used this stuff before? I was thinking about doing the lower 6 to 8 inches of the truck w/ the liner, to covewr up rock chips and other crap and figured it would keep it from rusting. I know if its prepped correctly you can have this done but if I can do it myself with the same results then why not. I cant remember the name brand but it was something I have heard of before. Just wanted to get an opinion or 2 or 3, to see if any one has used this stuff before. In tyhe spring I am planning on a roof rack and was thinking of lining the roof with the same stuff, it oxidized now and this would protect it if I drop any thing on the roof or through the rack. Gimme so feedback and Giddy Up! /forums/images/graemlins/peace.gif /forums/images/graemlins/burb.gif
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i used 3m,dupli-color or rustoleum(cant remember) profesional under coating on the inner wheel wells. most of it has come off. i washed the wheel wells down but never scuffed em up or anything like that. the stuff that doesnt say profesional on it sucks. i preped it good and a few days after it dried i could slide my finger on it and it would rub off. the can was with the duplicolor car paints.
  3. sublmnl1990
    Nov 8, 2004
    419
    Virginia Beach Va.
    yeah I have used that undercoating stuff aswell but this stuff is like the actual bedliner material, I sprayed some on the counter and it is still there.
  4. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    wouldnt hurt to try it. i thought you were talking about that stuff that come in a spray paint type can.
  5. sublmnl1990
    Nov 8, 2004
    419
    Virginia Beach Va.
    yes it does but I thought you were talking about the rubberized type under coating I am trying to explain this stuff is said to be the spray in bedliner like LINE-X. /forums/images/graemlins/thinking.gif
  6. sublmnl1990
    Nov 8, 2004
    419
    Virginia Beach Va.
    yes I rode the short bus to school /forums/images/graemlins/doah.gif
  7. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    I sanded the top and cab roof on my '78 Blazer and used 3 or 4 cans of the spray can bedliner before I put on my roofrack (which I got off a Pathfinder at Pick-n-Pull for $15) It has stood up to 3+ months of baking in the San Antonio sun.
  8. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I'm pretty sure that's what the PO of my truck did for the whole tub and it stands up pretty good, had a Q-jet, a steering box and a spare hub bouncing back there for a few wekks after I bought it and no dings.
    I'm planning on doing the same to mine, lining the bottom segment below where the trim was. Someone has a nice job of that, I think it's 70jimmy ? It's in the member galleries somewhere.
  9. big blazin sc
    big blazin sc Registered Member
    Oct 14, 2004
    24
    Spartanburg, SC
    I don't know abou the rattle-can stuff, but i helped a buddy roll herculiner in his tub of a rodeo. It is holding up great, u can also spray herculiner from a gun.
  10. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    Im getting ready to do this. Any special gun, or would a basic one work? /forums/images/graemlins/thumb.gif
    Z /forums/images/graemlins/k5.gif
  11. wkasak
    wkasak Registered Member Premium Member
    Jun 28, 2002
    59
    Elkridge, Maryland
    I used the herculiner roll-on for the lower half of the body below the moldings...has held up very well...prep is key...
  12. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    you probably need a presure pot setup and a primer gun with a 2.0 tip to spray most of that stuff and a good inline filter so your not adding rust from your tank to the mix.
  13. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  14. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    duplicolor in the can... works well and easy to touch up. Prep is important, also spray on one light coat and let it almost dry and go from there, don't try to build it up too fast cause it can lift the paint below it, and and it will sag. I shot my rockers with it like what you are thinking, and I like the results, also used it on my bumpers.
  15. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    It's junk, buy the Hurculiner it's good stuff. I lined the entire floor inside my Jimmy with the Hurculiner and havent had any problems with it. /forums/images/graemlins/usaflag.gif
  16. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    the stuff i used is flacking off.the cab is from TEXAS and rust free, so i want to keep it that way. i followed the inst, and still didn't work. thats what i get for being cheap. /forums/images/graemlins/grin.gif
