spray on liner prep HELP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k9man, Apr 11, 2001.
  1. k9man
    k9man Registered Member
    Sep 11, 2000
    5
    Capitola, CA
    I am trying to prep the inside of my blazer for a spray on liner but I can't seem to get the adhesive off used by the manufacture to glue on the carpet padding. Any suggestions would be greatly appreciated.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I caught hell trying to do this too. I ended up using a wire wheel, it does get everywhere but if you stop every once and a while and vaccuum up the stuff it wont be as bad. You could also try using a paint scraper or use a chemical such as Acetone or Zylene
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I used 3M adhesive remover (I think any brand will work- this was on sale at Pep Boys so I got it) and it worked for the most part. Some spots were very stiff and not coming off. I had to wire wheel those and scrape them with a razor blade. It was a HUGE pain to get those spots off. But I'm glad I did it because the carpet was very nasty and gross!
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  4. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    There are remover wheels for drills, I believe they are called "paint and varnish stripper". Basically black plastic fibers with a good ammount of airspace. Its not a great deefinition so maybe someone else can describe them better. They did wonders on everything in my truck before i did the bedliner. Although I didn't use them on glue.
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
