Spray paint and rust?
Discussion in 'The Garage' started by ChevyCaGal, Jan 10, 2003.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    What spray paint really stops rust? I've tried a few brands, even kinds that claim to stop rust and still I get it. I sanded down some spots on the body of my truck to the metal a few years ago and primered them over. Never had an issue until before Christmas. I noticed rust showing through! I can sand it off and treat it. It's nothing big yet. But I don't want to have it cause any real issues. So what brands actually really stop rust? I don't want to try something else only to find out again it didn't work and this time I have some real rust issues. Thanks!
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Rust in CA?!?!?! Is it possible?
    I've had pretty darn good luck with POR15. Just remember it works best when you remove the grease. It acutally bonds well to rusted surfaces. www.por15.com
  3. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    LOL, yes it does. It gets exposed to heavy dew and it rains here so moisture does show up on it. I was surprised. I thought rustolium (sp?) would keep that from happening, but guess not.
  4. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    If you have rust now, I would recommend using a wire brush and removing the loose rust, then applying a rust inhibitor. You can buy this at Wal-Mart. This will bond with the rust and stop it from spreading. Then you can paint over it. I was taught that surface preperation is everything when you paint. Take your time and do it right the first time. I hope this works for you.
    Jon
  5. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    get hold of some rust killer with phosphoric acid base like Captin Lee's Rust Away - that works great but dont get it on good paint. Got mine at autobody shop but a marine supply howse might have it too. ~$20 a gallon.
    Down here in Florida? All we got is mud, mud, more mud and rust /forums/images/graemlins/tongue.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Steph, did you paint over the primer? Primer is not intended to prevent rust unless it's covered with paint. Put a drop of water on it and watch how the primer changes color as the water soaks into it. /forums/images/graemlins/frown.gif It needs a coat of paint over the top of it to seal it.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I used POR15 inc, you can paint right over rust and it will stop it, it's a non-porous finish so it keeps the moisture out....
    por15
  8. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Ditto to what <font color="orange">HarryH3 </font color> said, primer won't stop rust at all, you'll need to use some sort of paint over it. Krylon, Rustoleum, etc all have worked on my vehicles in the past. You won't need to go as far POR-15 or Hammerite (but they will most definitely work) as long as you clean it up good before putting a coat on.
  9. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Only way i've found to stop the rust from the wonderful wisconsin road salt is to clear coat it. Primer, 2-3 layers of the color, and then 2 coats of clear coat. I clear coated my pickup tailgate, and no rust yet. Didn't use clear coat on the bumper from butch, and there are huge surface rust spots everywhere. It isn't much harder than the regular spray paint to lay down, but it does add gloss to the finish.
  10. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    I'm origanally from minnesota this is what i used to do wire wheel affected area than put naval jelly on it for a day then prime it and paint it por 15 works awesome on frames and rearends springs bumpers and just abot any thing I guess /forums/images/graemlins/truck.gif
  11. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    you can also use rust encapsulator from eastwood company. It doesnt have to be top coated right away either.
  12. TONYP
    Aug 13, 2002
    2,116
    so cal
    por15 have uv paint now, so it needs no top coat...
  13. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I used that rustolium and then sprayed some primer over that, and probably over time have added another coat of something. I was surprised is all because it said it works on metal and stops rust. Kinda why I got it. If it doesn't work then I would have got something else. Wish they'd say it works good, but not is for sure. The label makes it look like it's like the best ever when it really isn't... I guess next week when I get back (going to the snow this weekend) I'll be buying some thing else. I have used POR in a few spots and frankly I am not impressed. Maybe the new UV stuff is better, but the stuff that the sun hit has chipped and peeled away... thanks for the other recommnds for what to check into though! /forums/images/graemlins/smile.gif
  14. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    Even if you sandblast a rust spot to bare metal the rust can come back if you do not use a rust converter of some sort.
    I doubt any paint can work like a rust converter.
    It's easy and cheap insurance.
  15. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    First off rattel can paint/primer wont stop rust. What you need to do is take the rusty spot down to bare metal and remove all the rust. Then use some thinner to clean the area of any dirt and oils, even you skins oil will screw things up. Then use a tack cloth to clean off any lint. Next spray it with a good epoxy sandable primer. Now you can do any body work you need to do such as body filler. I would never use body filler aginst bare metal since its not a sealer like epoxy primer. Once you have done any body work that needs to be done spray it agine with a finish primer then paint it. If it's not sealed properly the rust will come right back.
  16. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Yes, it's called marketing /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
    The primer will need paint on top of it. Rustolium (sp?) is pretty good...but you have to paint over it. I know you have a camo job on yours, just get some flat paint and it'll look the same /forums/images/graemlins/grin.gif
