Spraying ice water in carb to loosen up carbon
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, Aug 20, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Someone replied to one of my posts about my carb and they said I should loosen up the carbon build up by spraying water in the carb while it's running to loosen up the carbon. Can you guys give me some details on how to do that? I don't want to screw it up /forums/images/icons/frown.gif .
    Thanks,
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Spray water with a spray bottle into the carb with one hand while keeping the engine running w/the other hand. Sort of "steam cleans " combustion chambers.
    Jim
  3. dyeager535
    26,980
    I'd suggest going out and buying GM's "top engine cleaner" or whatever its called. From all accounts, it is amazing stuff.
    To be fair, I've never tried the water trick on a known dirty engine, but I did on a newly rebuilt one, just to see how it liked the water lol. Just took a spray bottle and started squirting. (on spray, not stream)
    Didn't seem to hurt nor help the motor, and didn't even seem like I was putting much in there, as the exhaust wasn't even really steaming. May have been condensing inside the pipes though.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Try some stuff called Seafoam.... it's good stuff and you can even put it on there with the truck running....
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks everyone! I'll try them all!! /forums/images/icons/ooo.gif
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I did the seafoam trick. IT loosened the motor up. I was blowing stuff out the tail pipe for a while. The bad news was that I think I blew out everything that was holding the poor motor together. It died about amonth later /forums/images/icons/frown.gif
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    After you use the engine cleaner, be sure to do an oil change to get it out, because the engine doesn't get lubed well with the cleaner in there.
