spring and axle swap
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70jimmy, Jun 4, 2002.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    I found a 68 chevy 4 wheel drive 3/4 ton. I think it is dana 60 rear. Has 4.11 gears. I am thinking of trying a spring and axle swap. I havent measured anything yet. anybody know what I will have to do to make this work??
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I guess the first step is measuring the eye to eye and then eye to center pin on the springs and compare what you find between the two. then location of spring perch & brake hardwre.
    Good luck
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    It should bolt right in. I put a Eaton from a '72 K20 in my '70 K5. Bolted right up.
