Spring and shackle bolt sizes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Jul 1, 2002.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im gonna be putting my lift on and want to get new bolts. Does anyone know what size and length for the front and rear springs and shackles?
  2. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I believe they're 7/16 from the factory on my 89. I got the ORD bushings and shackle kit and those are 1/2", just make sure that the sleeves in the bushings match the bolt diameter. FYI - The ORD bolts are drilled and fitted with grease zerks (sp?).
    John
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Very front spring bolts and all the rear spring bolts are 9/16" and the front spring shackle bolts are 7/16" from the factory.
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yep, those are the right sizes. The 9/16" bolts on the front are 5" long, and the back are 4 1/2" long. They are grade 8, and use Nylok nuts. I had to buy mine from a fastener supply company.
    John
