!@#$ Spring bolt.. how in the hell do you get it out HELP FAST PLEASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Jun 5, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    RUSTED putting on my springs has been a simple. Last bolt is being a PIA. I dont have a way to heat it up. I used ever oil i own, still will not move!!! /forums/images/graemlins/angryfire.gif Whats next!
    Mike
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Are you talking about the centering pin that holds all the leaves together?
    First, take a c-clamp and clamp them together so that they don't fly apart when you take it out. If it's rusted really bad then you can grind /forums/images/graemlins/grind.gif or cut /forums/images/graemlins/hack.gif the head off. You could also just take a couple of vise grips and twist the head off since they aren't very big. Then go get some new ones. Most parts shacks will have them for a few bucks each.
    If you're talking about the spring eye or shackle bolts then an air gun works great if you have one avaialble. /forums/images/graemlins/whistling.gif Otherwise get a long breaker bar and pull like the dickens.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I broke my breaker bar. i think i am going to try to heat it some way. thanks mike
  4. MR4WD
    MR4WD 1/2 ton status
    Jul 28, 2002
    133
    Fort McMurray, Alberta.
    use a grinder with a cutting disk to reach up between the old leafs and spring pockets and cut the bolt out.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have actually had that problem a few time.
    I got a 3/4" breaker bar with the 3/4" sockets with a cheater bar I was able to take the nuts off.
    Some trucks that's all it took, some the bolt was still stuck in so i had to press it out with my U joint press.
    The last i did that didn't work so I used the sawzall and cut the bolt from the inside of the spring hangers.
    /forums/images/graemlins/waytogo.gif
  6. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Re: !@#$ Spring bolt.. how in the hell do you get it out HELP FAST PLEAS
    I had to use a saw on one of mine, the nut came off but the bolt was frozen, 0 Degrees Kelvin frozen
  7. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Die-Grinder with a 3/32" Cutting wheel /forums/images/graemlins/smile.gif
  8. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Be a man...use a 7" grinder with a cut off wheel. /forums/images/graemlins/grin.gif I don't even bother looking for the right wrench or sockets for that anymore, just cut the bolts and press in new bushings with new bolts.
    Rene
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Rene
    haha! Thats no joke. I have a 7" Dewalt grinder and use worn out 14" chop-saw wheels on it. I cheat death everytime I fire that thing up. I think it's the most dangerous tool I own. With a fairly worn out wheel on there, my hand is only like 2" from the wheel as it spins. The death machine. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    Well you are talking about cutting the heads off.
    Well I did that and one of them still wouldn't go out, it was one with the bushing so I had to cut from inside of the spring hanger.
    /forums/images/graemlins/peace.gif
  11. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    No, I'm not a retard, I only want to cut once and be done with my portable finger eater. I cut inside the hanger right next to the spring, then drill out most of the rubber bushing until I can push the remains out.
    I usually use an 8" cut off disc on my grinder.
    Of all my tools I have at my buddy's place, the only one he was 'scared' of was my 7/9" Makita grinder. /forums/images/graemlins/smile.gif
    Rene
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    Hey I didn't say you were.
    Are you saying I am? /forums/images/graemlins/yikes.gif /forums/images/graemlins/shame.gif
    J/K
    Well you learn from experience. Now I try turning the bolts first if the bolt and the bushing sleeve turn as one, I don't bother, I cut on the inside.
    I am sure some are wondering why I say next time... Well I have that operation once every few weeks, for parting out a truck or upgrading one of my many trucks. /forums/images/graemlins/peace.gif
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Nut came off too. Bolt it self is frozon. Cuting it today. thanks guys mike
  14. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had to cut two of mine with a sawsall on my last go around. Now I take them apart and grease them now and then.
  15. GORRILLA
    GORRILLA 1/2 ton status
    May 3, 2003
    315
    TX panhandle, out at the river.
    I to believe in the "PORTABLE FINGER EATER" approach.
    But, eat your Wheaties, lift wieghts when you can, by all means "WEAR GLOVES", and use the best stuff of the planet,
    /forums/images/graemlins/bow.gifPB blaster /forums/images/graemlins/bow.gif
    When I say this, I mean plan ahead. One week before you even think of turning a wrench, soak them every day, 2 or three times a day.
    If that fails, I prefer a 2 stroke demo saw and thoughts of an ex wife to get the job done.
    /forums/images/graemlins/thumb.gif
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    PB is the best but I tried on that one and after a week nothing changed.
    I cut it and then pressed it out on my 20ton press and it scared my neighbours with the screeching it did.
  17. GORRILLA
    May 3, 2003
    315
    Your situation struck a nerve. Mine was the damn steeering arm. I don't know of anything more frustrating than that last bolt that wants to be a beotch. /forums/images/graemlins/thumb.gif
    OR, having 4 wheel parts send you the wrong springs!!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  18. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well for the steering arm, I found a way.
    Most times the cones are so pressed on the studs that they develop threads.
    I use a chisel, stick it in the split and hit it to turn the cone like a nut and loosen it up.
    It comes out after a couple of whacks and you spin it off like a nut.
    Hasn'r failed yet.
    It happened by mistake when I was trying to pry it open so it pops out and I have been doing that ever since.
  19. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Spent a while today with /forums/images/graemlins/hack.gif. Really didnt even make a dent in that grade 8 bolt!! Got pissed nailed it a few times with a BFH. Got it to mave a inch and that is it!!
    !@#$ BOLT1!!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif If i use a torch would i hurt the bracket? Just got one form a sale for 100 bucks. How many turns out on each would i need to cut anyway? PLMK so i can get this done.
    Mike
  20. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Sawzall is useless on those bolts...use a grinder with a cut off disc. Get the disc up between the spring and the INSIDE of the hanger...just cutting off the head of the bolt won't help you.
    Rene
