Spring bolt removal
Discussion in 'The Garage' started by sandy78, Jan 13, 2007.
  1. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    Okay, I'm dropping my 10B w/Springs attached to make room for my 4" lift and D60 :D . I am having great difficulty with the bolts holding the springs on to the truck. They are almost 30 yrs old, and sledgehammer is having trouble convincing them to leave. Since I don't intend to reuse the springs, I am thinking of cutting the bolts inside the mounts with either sawsall or angle grinder. Has anyone used either? Which worked best? Anything to watch out for? Thanks.
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I had the same problem with my rear spring bolts The sawzall just wasnt cutting them so I used the angle grinder
  3. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
    if u can get a big angle grinder (7-9") thatd be perfect. my 41/2 once the tip wore offf the grinding wheel i had to get a new 1. then i just got mad and used the torch. and sawzalls do nothing to grade 8 bolts
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I've been there. sounds to me that the sleave inside the bushing has frozen to the bolt and that bolt is going no where. I used an angle grinder, I had to get creative on the angles inorder to cut more into the bolt. Also I just went straight through the bushing and burn bushing doesn't smell good. :eek1:
  5. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    Exactly I couldnt have said it better.:bow:
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Make sure you put some anti-sieze around the new bolts when they go in. It will keep this from happening again.
  7. goldwing2000
    goldwing2000 Guest
    I used a torch. Angle grinder would be the next best choice.
  8. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    The only way to do it! Run a larger diameter thin wheel between the hanger and spring itself and cut the bolt. WATCH YOUR FINGERS!
  9. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    i use a air hammer with button head thats concaved so it wont fall off the bolt wile hammering on it. this will 75% of the time release it from the death grip of rust. but if not heat the bolt up on the head and threads. let it cool and the heat will soak in then air hammer it again. this will get them about 95% of the time. last is cut it out 5% of the time.
    once it moves to the point you cant hammer on it. then drive it back in and back out a few times this will push the rust out.
    and i live and work in the rust belt of he!! thay dump salt all winter long around hear.
  10. sandy78
    Nov 28, 2002
    84
    Utah
    Spring bolt removal report.
    Went to Home Depot and picked up a 7" metal blade for my Skil circular saw. Cost me $2 and went right through them. I really wouldn't have wanted to reuse as they were really rusted away. Rearward shackle hanger bolts came right out just like they were put in yesterday. No rust or anything. Go figure. Thanks for the suggestions guys!
