spring bump stops
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87 mid canada k5, Mar 30, 2001.
  1. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    I need to extend my bump stops, do I just have to change to bigger rubber/ urethane? Put a spacer between the bracket and rubber that's there now? Change the brackets themselves? What's the best\easiest way y'all found to fix the problem? WHEW!
    Denis
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Call ORD. They sell extended bump stops that bolt in the stock location...
    EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com
    "Pimpin aint easy!"
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can bolt a short piece of 2x2 steel between the factory bump stop and mount. Or you can spend $50-60 for some of those trick oversize polyurethane bump stops.
  4. 87 mid canada k5
    Jul 20, 2000
    105
    thanks much guys!
    Denis
