Spring bushing removal
Discussion in 'The Garage' started by steve_kibbe, Jan 4, 2006.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I was working on my rear springs yesterday, having a time fighting with getting the old rubbers out. I drilled some holes, the realized I should try using a hole saw.
    All I can say is it worked like a champ. Ate right through the rubber, had them out in a few minutes.
    Just thought I'd pass it along.:D
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    interesting. i never thought of that. i just used a drill bit. drilled some holes in the bushing. after about the third hole, the drill bit walked around the perimeter of the bushing on accident. it seemed to work pretty good, so i began doing it intentionally. drilled em out good, then used an air hammer to buzz em out. chisel to remove the sleeve. worked great, although yours sounds easier yet.
  3. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    I thought I was the only who used hole saws to get rubber bushings out. I gouged the sleeve on the frame once getting a bushings out with a hole saw, but now I've perfected the technique. Steve is right, it works like a champ.
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i tried the hole saw technique too, it worked pretty good but you got to be careful not to gouge the spring eye ID with the saw.
  5. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    Ive always preferred to use the :weld: technique. Love the smell of burning rubber:D :D
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Anybody pass that along to Steve (ORD), or I may have just now. Great tip, seein as how I have about six more to go.:haha:
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I had the bit so hot I smelled burning rubber:D
  8. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I was doing the rear springs, had to take the sleeve out anyways:D
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    sleeve is the easiest part, with an air chisel.
