Spring "clamp" is loose-problem?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ressurection, Aug 6, 2001.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Spring \"clamp\" is loose-problem?
    Just noticed the little "clamp" like thing that's supposed to be riveted to one of the leafs broke loose. Is this a problem? Can this be repaired? Now I know what the rattle noise is from the front!
    "High compression engines take longer to start!"
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Spring \"clamp\" is loose-problem?
    Any suspension shop should be able to get you a set of bolt on ones. You should replace it esp. on the front (because of the push pull steering you might bend the spring).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
