spring clamps and overloads
Discussion in 'The Garage' started by sandawgk5, Dec 31, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have a set of 56s that already have been thinned down to 5 leaves. Problem is there is no overload or spring clamps. Is this bad? Overloads are easy as I can just find some and bolt them on but the spring clamps I have no way of putting those on as the spring has no hole for them. Can I remove a teflon pad and bolt a clamp on in its place? It will then only capture the 3 top leaves.
    Any help or ideas appreciated
    Ira
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    u dont have to have the clamps.u will get more droop with out them but u might bend or break the main leaf witch is bad.
  3. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    My springs were too much lift so I removed the overloads from the spring pack. No problems so far but I don't tow anything or load my truck down with anything more than 500 lbs or so. I don't have clamps on my front springs. The backs only have the top two clamped together.
  4. sandawgk5
    Oct 28, 2003
    6,881
    does anyone know where to get springs clamps? I mainly want them to keep the leaves from fanning out.
    Ira
  5. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    not to hijack or anything but i removed my overloads in the back with a echobit flip because i had too much lift. how much weight do you think i could haul back there like parts or w/e? and how much do you think the springs oulw droop? once again sorry to hijack.
