Spring Eye Bolt Removal Tips
Discussion in 'The Garage' started by bluehen, Mar 13, 2006.
  1. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    I thought about doing a search and tagging this on the end of an old thread, but figured I'd do a new thread to help out the next guy that does a search.
    I just finished installing my 6" BDS full spring kit this weekend. The eye bolts were nothing short of a beeyotch. Particularly in the rear, where I couldn't swing at hammer.
    The best method I came across was to run a cut-off wheels just outside of the spring eye's. A 4.5" cut-off wheel will reach far enough into the bolt to sever most of it. Cut both the bolt on both sides of the spring leaving just a small portion of it. I was nervous to cut all the way through for fear of the spring torquing and grabbing the cut-off wheel. Then pry or pound to safely complete the break. Punch out the bolt head on the outside of the frame, then run a punch through the shackle or hanger to the opposite side bolt end and nut.
    This method shortened up removal time to 10-15 minutes. You'll need new hardware and you'll still have to figure out some way to get the old bolt/sleeve/and bushing out of the spring if you need to reuse them, but atleast you can do it on a bench. Good Luck, all.
    Search Qualifiers: rear front shackle spring eye bolt removal
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    And if you live in here in the west, a good method is to pull it out with your fingers.... lol ;P
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Ya I had to hammer mine out with my index finger:D .
    Ira
  4. bluehen
    Nov 11, 2004
    215
    DE
    Yeah Yeah Yeah... "we don't know what rust is..."
    I bet you guys didn't have any troubles with your steering arm either. That sucker never did come off. Mine's on there so good, I should start a contest to see who could break it off. I just consider it an extension of the knuckle at this point.
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have had some where I had to use that method and others where they just came out.
  6. sandawgk5
    Oct 28, 2003
    6,881
    I changed my steering arm by removing my Ubolts and swapping in a front 60:D .
    Ira
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I bet I could get it off, nothing a 16 lbs sleg can't handle
  8. bluehen
    Nov 11, 2004
    215
    DE
    cegusman, you're more than welcome any time to come to my garage and try your hand at the steering arm. I keep plenty of beer on the chill at all times.
  9. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    :haha: :haha: :haha: You got that right.
  10. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    To bad your to damn far away or I would take you up on your offer
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    When I pulled the rear springs off my '87 C10 donor truck, I used an air hammer with a pointed-punch chisel to push the shackle bolts bolts out. I used a 1/4" drillbit to make "cups" in the threaded end of the bolts, about 1/4" deep, so the punch wouldn't skip off the bolt.
    Even that took almost a minute of hammering with the air at 110psi... stupid rust.
  12. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I had to use a bfh and lots of pounding to get my rear spring bolts out
    next week I'll be changing out the front springs I hope they're not as stuck.
  13. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Yeah I am in the middle of replacing my 4in lift springs, and so far the rear has been a pain in the ass. I used my angle grinder a lot. I had to cut 4 out of 4 eye bolts on the rear springs. The front doesn't look so bad, but only time will tell.
  14. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    The inner sleeves rusted to the bolt on my parts truck leaf springs. Just took a sawzall in between the the hanger and springs, took part off the bushing but not like it mattered. Poly bushings heated up from the sawzall smells like cherry vodka :whistle:
  15. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Bluehen, I'll be in Delaware in Nov. If you don't have that arm off by then, I'll take a few swings at it!​
  16. 85k30
    85k30 Registered Member
    Jan 1, 2003
    24
    i used a ball joint press to force them out.
  17. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    after some of the worst day(s) of my life, i used my torch to burn up the rubber bushings. then a few more hours of sawzall and grinding went by. finally those miserable spring pieces of **** came off. then i used what was left in my torch to cut those leafs into unrecognizeable pieces of metal. then i lowered them into a vat of hydrochloric acid so that they could never send a robot back in time to kill me before i was born.
  18. bluehen
    Nov 11, 2004
    215
    DE
    LOL... I appreciate it. Hopefully I'll have a D60 up there by Nov. and it won't be an issue. Send a pm when you get in town though. I'm in and around Dover alot. Especially in Nov. (startup of hunting season)
  19. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Living in the midwest there are several parts on a truck that when disassembling I don't even think about turning a wrench.
    Spring eye bolts, we also use a cutting wheel but its 7" diameter to start with.
    U bolts. (Torch)
    Factory bumper bolts (Torch)
    Those are the worst that come to mind.
  20. goldwing2000
    goldwing2000 Guest
    Yep. My flame axe is my favorite tool.
    The flame wrench is a close second. :D
    Something about the smell of burning steel... :saweet:
