spring eye bolt removal ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by crazydave72k5, May 17, 2002.
  1. crazydave72k5
    crazydave72k5 Registered Member
    Apr 22, 2002
    6
    HOLIDAY,IL
    anybody have a good trick for this i have done it before but what worked last time doesnt seem to this time thanks dave
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    patience and persistance works for me/forums/images/icons/smile.gif along with a BFH, WD40, vicegrips, hacksaw, long punch.
    ARQ.
  3. crazydave72k5
    Apr 22, 2002
    6
    HOLIDAY,IL
    i tried all of the above today except the hacksaw but i went through 4 sawzall blades to remove one front spring but il be ready to start fresh tomorrow thanks
  4. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    torch or grind the bolts off. Then cut out the bushings and get newones from the spring shop.
    I know but you will apprecieate it in the long run. Same deal with most u-bolts...
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i just beat the hell out of mine with a hammer and a punch.still took a while though.also 2 or 3 days before i went to do the work,i start spaying it down with wd 40 every couple of hours.
  6. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    PBlaster and Liquid Wench work better as a penetrating oil than WD40. Just my experience.
  7. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Aero-Krol is an awesome penetrating oil. An air hammer with a round bit is less work than a hammer and punch. Lenox are the best saw-z-all blades, expensive but worth it.
