Spring Eye shackel bolts
Discussion in 'The Garage' started by 1979jimmy350, May 20, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Is there any good trick to getting theses bolts out. I have hit them with a 20 pound hammer and they will still not move. I can't use the torch because they are right next to the gas tank.
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    3' cheater bar? if that wont work, try a grinder.
    j
  3. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    good air chissle with concave button head. and also a long punch head . this with spinning them with the air gun will help.
  4. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    no sparks...
    Near the gas tank huh--that sux...safest way with no open flame or sparks is a sawsall--cut the bolt by putting the blade between the spring eye and the hanger(cut on both sides)..and deal with it later when the spring is out...OR--
    I've had success getting the bolts out by cutting off the bolt head after removing the nut,and grind it flush to allow it too "pull thru" by adding washers to the nut side and tightening the nut,and add more washers as it pulls thru..this is very difficult if the head of the bolt is toward the frame,on some trucks it is.(sawsall is easier in that case)... .once you get the bolt the pull thru even a little,it usually comes free from the sleeve in the bushing with a little hammer and punch persuasion.. :crazy:
