Spring eye torque
Discussion in 'The Garage' started by FL84K5, Mar 1, 2004.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    How tight is everyone tightening the bolts at the spring eyes on their trucks? /forums/images/graemlins/confused.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Mine are all at least 70 ft*lb but I think the spec for regular bolts is around 50 ft*lb.
  3. 85army tank
    85army tank 1/2 ton status
    Sep 25, 2002
    276
    southren mn
    /forums/images/graemlins/k5.gifOk on a 1985 k5 it calls for front eye bolt 90ft lbs and rear eye bolt at 50 ft lbs. I got this info from a system called mitchell in demand from tec school cause i am going to be replace my diffs and put a 4 in lift on mine so as far as i know this is what the factory spec calls for. /forums/images/graemlins/k5.gif
