Spring measurements
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Hossbaby50, Jun 12, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Would one of you first Gen guy give me a hand? I need you to measure how long your front leaf springs are and how wide the are. What is the eye to eye length of them installed in you truck? What is the width of the spring? Thanks
    Harley
  2. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    changed the question a little. THanks
    Harley
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Does it matter how big (arch) they are?
    Basically, mine arent stock, if it matters to you.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The eye to eye length should be the same as stock. The difference is the amount of arch in the spring. I just need the measure straight from the center of one spring bolt to the center of the other spring bolt. Thanks
    Harley
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    1st gens use a spring that is 2" shorter then a 2nd gen.
    47" vs. 49" IIRC
  6. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I get 43", 2.5" wide.
