spring pad spacing
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by greythorn3, Dec 19, 2006.
  1. greythorn3
    greythorn3 1/2 ton status
    Oct 14, 2002
    174
    Anchorage alaska
    i was wondering what spring pad spacing on a 70 blazer was compared to a say 84 k20? im thinking about swapping ina 14 bolt and getting rid of my 12 bolt...
    Ray
    :eek1:
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    You will have to move the spring perches if you use that axle. If you get a 14 bolt from a 1 ton, the spring perches will be in the correct position.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i wanna say it is a 1.5" difference between a 67-72 k5 and a 80's k20
    On my 68 i used a k20 axle and i used the k20 spring brackets.
    I didn't wanna torch the axle mounts as I may swap axles again.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    1st gen blazers are 40.5" spring pad spacing. The 2nd gen blazers are 42.5" spacing.
  5. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Am I correctly assuming you're talking about REAR spring perches :eek1: :dunno: ?
    I'm about to put in a CUCV front D60 and their spring perches measure 32".
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes i was refering to rear, ALL GM fronts are the same.
  7. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    Whew! Thanks for the confirmation :D :bow: !
  8. greythorn3
    Oct 14, 2002
    174
    Anchorage alaska
    hangers?
    are you talking about the rear spring pad hangers? then you dont need to move perches? did you use the offroad design revers ones for a 73-87? or the stock ones of the 80's truck?
    ray
  9. greythorn3
    Oct 14, 2002
    174
    Anchorage alaska
    Yukon Jack
    i got a flatbed 69 truck too! hahah yurs is nice! king of a bad picture! you get the idea though.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    what i used was the axel out of a 78 burb. so I used a 2nd gen ORD flip with some pickup front hangers. also gained 3" more lift cause of the height difference
  11. greythorn3
    Oct 14, 2002
    174
    Anchorage alaska
    55wilyl
    thats what i would like to do in order to get rid of these damn 4" blocks in the rear. i hate blocks.. do you happen to have a part number?
    Ray
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I can look tonight, they were all stock GM pieces so i think the GM tag is still on them. i had blocks too but after doing the brackets I won't be needing them.
  13. greythorn3
    Oct 14, 2002
    174
    Anchorage alaska
    part #'s
    the ORD ones?
  14. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    ord's part number is on thier site. I already had a 2nd gen flip on my 77 so thats why I wanted to use it. i was gonna drill the front brackets off of the 77 k5 but the truck ones i got were taller. the old ones on my 68 looked more like a 2wd model they were really short, spring eye was about 1" below the frame.
