Spring pad with question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sdavid, Feb 25, 2006.
  1. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Will a semi-float 14b out of a 81-87 2wd 3/4 ton work in a 81-87 K5 with out modification? Are the spring pads the same width? If I wanted to convert it back to 6 lug, would that just be a simple axle change? Thanks for the help.
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    1 ton is the diffrent only. and then if you realy didnt want to move perches its the hangers that are diffrent. so to answer your question yes it will bolt in.
  3. sdavid
    Aug 5, 2002
    244
    Livingston, TX
    Thanks. I thought that was so, just was not sure about the 2wd versions. Are the axle shafts interchangeable between 8 lug and 6 lug on a semi-float 14b?
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    thay didnt make a 6 lug in the 73-87 style that i know of. and the newer 88-up i am sure went wider. so to do this it might be use the 88-up style housing and get the 6 lug from a light duty 2x4 3/4 ton or 1/2 ton with trail towing package option. or the 8 lug from heavy 3/4 ton or light 1 ton.
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
