spring perch clarification !!
Discussion in 'The Garage' started by nstarry, Nov 22, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    sombody in here said that the 1/2 ton and 3/4 ton GM trucks rear spring perches are the same
    is this right ?????????? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  2. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Yes in regards to placement, so if you're just swapping axle housings no problem. Rear axle tubes are different diameters I think so I dunno about fitment that way. I've been making my own from box tubing.
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Yes, 1/2 and 3/4 are the same, 1 tons have a wider placement, but it is ane easy fix. Just cut them off and weld them back on at the right width. 1 tons also have a different shock mounting set up.
  4. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    so is there a diference in the years because my 72 3/4 ton had wider springs then my 74 k5 ???
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here is the break down on spring perches....
    67-72 2wd 1/2-3/4 tons = 42.5" center to center
    67-72 4wd 1/2-3/4 tons = 40" c to c
    73-87(91) 2 & 4wd 1/2-3/4 tons = 42.5" c to c
    77-87 1 tons = 40.5" c to c
    I had to cut off the perches on my '77 3/4 ton 14BFF and weld on new ones at the 40" spacing to fit my '71 Burb. /forums/images/graemlins/waytogo.gif
  6. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    you just made my day thanks for the info /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    anyone know the width on a newer IFS rig? I have to put a 14 bolt under one temporarily.
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Sure! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
