spring perch dimensions.
Discussion in 'The Garage' started by makovai, Nov 7, 2006.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I need to know what the exact measurement of the 72 and below spring perch dimension as well as the 73 and above. For a 14 bolt. From center pin to center pin.
    If somebody's has a link to a site that shows real dimensions from the factory i would really appriciate the link.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    1/2t and 3/4t are the same from 73-91.
    1t (whatever year they started to 91)and 72 and prior trucks are the same.
    Don't have dimensions, but I'm 100 % on this.
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    1 tons and 72-earlier, 40.5"
    1/2 and 3/4 ton 43.5"
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Actually it is 1 ton and 72 and earlier are 40.5" and the 73 and later 1/2 and 3/4 ton are 42.5"
  5. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    uhhh...my 69 k5 has a '75 dana 44 under the front didn't change a thing except brake lines it bolted right in so what gives?
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Rear axles.
    Fronts are all the same.
  7. makovai
    Jun 6, 2006
    854
    oregon city
    Exactly, i'm already finished with the front, it bolted right up. But in 73 Chevy widened the rear of the frames and my 78 14 bolt wont mount to my 72 frame without perch movement. I have already cut one side of the perch and shock mount off, but i'm gonna weld the new perch before i cut the other side off.
    Another question?????????
    I have 8" of suspension lift, should i add the angle when i weld the perch on or should i leave the angle piece under the springs, and weld the new perches on the same angle as stock?
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If it were me i would only tack weld the perch in the position you feel is right then install the axle and check for angle, if it needs correcting i would then break the tack welds and readjust then final weld without using shims.
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Let me point out that the 1 ton 73-up and the '72 and older distances are close. The '72 and older actually measure 40" center to center.;)
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    let me add that the frame is not wider it is all in the brackets to line up to the spring perches. I have a 68 but run a 78 14bolt with my 2nd gen flip with a pickup front hanger to widen the stance.
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I believe the 72-older 2wd w/leafs (1/2ton & 127"WB 3/4ton) are wider spaced than the 4x4s.
  12. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    Measurements
    I measured an 89 GMC 3/4 4WD diesel Suburban last night - since I am stripping it.
    Front Springs - 32" width on center, perch to perch 46 3/4"
    Rear springs - 42 1/4" width on center, perch to perch 55 3/8"
  13. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    yes, eliminate the shim. remove both old perches. assemble everything loosely without any welds. then you can fine tune the angles and side to side. measure from the backing plates to the perch to center it. then when you have everything where YOU want it, tack weld the perches. unbolt the u-bolts and finish welding.
  14. makovai
    Jun 6, 2006
    854
    oregon city
    Hmmm.... i kinda want to do 1 side at a time. but you make a very valid point.
  15. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Its definitely much easier to do it with the axle temp mounted under the rig to get your angle just right.
  16. makovai
    Jun 6, 2006
    854
    oregon city
    easier for you guys :D
    I have a 7' door with an 8' truck :haha:
    I need to find a set of cheap 8 lug wheels for the front.
    I am certainly not working on this rig with the 4" of rain per day we have been having. Last winter i did a crate motor in Janurary in the snow. I'm getting to old for this :doah:
  17. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I have a 7' door and an 8'6" truck. :mad:
    you only need to put the back end into the door. close enough for the leads on the welder to reach. put the pinion back in or use an angle finder against the mounting surface. If you do it outside the truck and have the perches off even the slightest amount you will need to take it all back apart again.
    It really is the best way if you don't have a fancy jig to make sure everything is perfectly straight. jackstands and a concrete floor are not accurate enough for me.
  18. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Jim, just roll it in on an old set of rims
  19. makovai
    Jun 6, 2006
    854
    oregon city
    thats what im gonna do. I'll start looking on C/l for a cheap set of 8 lug and roll it into the garage for a week or so. I dont want to be rushed.
