Spring perch mounting surface not flat - problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Feb 24, 2003.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I recently discovered that the spring perches that I had welded onto my 14-bolt are not flat across the mounting surface (where the spring meets the perch). There is a slight depression in the center of each perch (running the full length - front to back) where the spring does not touch the perch. Is this something that I should worry about?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I would say you'll be fine, but only under the following circumstances.
    Make sure the center-pin is in the hole, that's a must.
    And, it probably won't work if you're using aluminum lift-blocks or shims. (They'll break in half when you tighten down the u-bolts)
    Are the springs mounted on the perches right now with the u-bolts tightened down? If so, how much space is in between the spring and perch?
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would worry if it was the opposite, that is when the springs start rocking on the axle and you can break the driveshaft Ujoints.
