Spring perch question ... need to have new one's welded on.. but ...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Aug 9, 2003.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Spring perch question ... need to have new one\'s welded on.. but ...
    My 14 bolt is from a 1-ton truck.. I need to have the spring perches cut off and new ones rewelded on.. how far do the spring perches need to be moved from the 1 ton to 3/4 ton measurments on the axle.
    Don't know if this is clear or not.. but I have to spread my springs to install my axle..
    Thanks in advance.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Re: Spring perch question ... need to have new one\'s welded on.. but ...
    A K5's spring perch distance is 42.5" center to center. A 1 ton's perches are at 40.5". You you'll need to move them both out by 1". But make sure they end up centered on the axle and are at 42.5" The easiest way to check if they are centered when you are mocking them up is to measure the distance to the backing plate mounting flange.
    I had to do the opposite, I moved the perches from 42.5" to 40" for my old Burb. /forums/images/graemlins/thumb.gif
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Man I hate to think what is ahead of you. removing them things suck no matter what you do...
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Torch em off!
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    You have that backwards.... THe K5 spring perch distance is 40.5".... The 1 Ton's is 42.5".... Charles, you will have to move each perch 1" in towards the pumpkin! Just get cutting, it won't take too long!
  6. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I beg to differ. 73-up K5's are 42.5" Anyone else want to back me up on this?
    Rocko's K5 is an '89, so it would fall into the 73-up category. /forums/images/graemlins/thumb.gif
  7. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Check out this thread.
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    ....and this one.
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    ...and this one. /forums/images/graemlins/thumb.gif
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You are right, an '89 K5 will need perches 42.5" center-to-center. /forums/images/graemlins/thumb.gif The one ton axle will have them 40.5" apart.
  11. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    The one tons are narrower to make up for the posibility of daul rear wheels. With the duals on the inner tire would hit the springs with the wider perches.
  12. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep, that's what I said in my above post. /forums/images/graemlins/thumb.gif
  13. Batmanjr
    Mar 23, 2001
    1,537
    I don't know why mine would be any different than ya'lls. but I just measured my springs inside to inside front and rear of the perches and they are 40.5" apart.... Not to mention.... Charles has been riding on a 1 ton axle for the last 6 months to a year and when he dropped his blazer on the axle, he had to SPREAD the springs APART to fit the springs on the perches..... I'm just going from what I measured.... My springs are the exact same width apart as a stock K5.... they are 40.5" apart....... Please explain......
  14. Batmanjr
    Mar 23, 2001
    1,537
    Alright, I just measured my 83 Blazer.... It is exactly 40.5" from the inside of one spring to the inside of the other spring.... They match exactly and I have stock rear springs and stock hangers on this one...... NOTE: I am not measuring from center of perch to center of perch.... This is from inside of perch to inside of perch! Also, my 83 Blazer has a non-modified 3/4ton rearend under it!......
  15. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    You are measuring inside to inside. The center to center distance is 42.5". The 1-tons measure 40.5" center to center. So, to put a 1-ton 14BFF into a 73-up K5, you will need to move the perches outward 1 inch each.
    The van 14BFF is different story, wider WMS width and perch spacing. /forums/images/graemlins/thumb.gif
