spring perch tech
Discussion in 'The Garage' started by big83chevy4x4, Aug 13, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    would making the spring perches longer benefit me in any way? i have 18" of 2.5" 1/4" wall square tube and was thinking of making the perches 8" long as oposed to the stock 6". seems like it would help with axle wrap a little, but then it seems like they will be way too long and may bind or catch on something.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Might be better if you ever want to move your axle around. Would give more support if you wanted to move it forward or back.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    well i decided to cut them at 6" and weld the 5/16" caps on it, so the actuall part that touches the spring is 6" long. i don't plan on moving the axle any time soon (expect to correct for the shackle flip). if i do move the rear axle its when i go with something other than leafs in the rear.
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Heres a set I made. 6" out of 1/4 2.5x2.5. 1/2 plate on top and inside. I'm gonna make another set but I will be making them 8" so I can move my axle back.
  5. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    so longer spring perches help with axle wrap?
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    gives the spring more solid space to sit on. in my mind, more solid space its sitting on, less spring to wrap and more place for that force to go. Always heard longer perches help axlewrap, no experience with it.
  7. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    it helps the same way an overload helps. if you have an overload still, then those perches do not need to be any longer.
  8. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    ah, makes sense
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    There are some manufacturers of spring perches that make them longer for the sole purpose of controlling spring wrap. I have installed some for jeepers who have converted to a spring over configuration.
  10. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I tried a couple of different lengths of perches on some SOA samis and Jeeps they don't help much so if you have an axle wrap problem its probably not going to cure it. One suggestion after watching mine very carefully, is to make sure the edges are beveled. the longer your perches are the more stress is put on the spring at the very edges and beveling them takes some stress away
  11. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Couldn't be said better!
