Spring perch widths
Discussion in 'The Garage' started by ntroffroad, Nov 9, 2005.
  1. ntroffroad
    ntroffroad Newbie
    Nov 9, 2005
    4
    northridge, CA
    Does anyone know what the spring perch width is in the rear of a 72 K5 vs. a 78 K5?
    Thanks in advance.
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    '72 & older = 41.5"
    '73 - '91 = 42.5"
  3. ntroffroad
    ntroffroad Newbie
    Nov 9, 2005
    4
    northridge, CA
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I must disagree my good sir......
    The 1972 & older 4X4 spacing is 40" center to center. :D
  5. ntroffroad
    ntroffroad Newbie
    Nov 9, 2005
    4
    northridge, CA
    Great, 2 different answers. When I measured, I thought it was 41 1/4" so the 41 1/2" sounds better than 40"
  6. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Where are you measuring?
    My rear axle is a 14BFF from a '77 3/4 4X4. I had to move the perches from 42.5" to 40" to get under my '71 Burb. 1972 and older 4X4's measure 40" center to center of the perch......that is 100% correct. :D
    1972 and older 2 wheel drives with leaf-springs have a 42.5" spacing.
    Are you measuring a 2wd or 4wd?
  7. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    the one ton axle I have was 40.5 " and I had to move each side one inch out for my 81' blazer to 42.5"
  8. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    DOH!! :doah: You're right! For some reason the newer 2WD dimension popped into my head. It might be because we swapped a 2WD 14BFS into a '72 4WD blazer recently. We had to narrow the perch spacing
    Sorry about that ntroffroad.
