Spring Perches from Ruffstuff, Perches that Fit!
Discussion in 'Vendor Forum' started by Gravel Maker, Oct 14, 2006.
  1. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Spring perches, pretty basic, but made in 3 widths (2", 2 1/2", & 2 3/4") & 4 axle diameters for a perfect fit and not a "good enough" fit. With 3 pin placement options and long enough to help in controlling axle wrap. I'm only going to show you 1 perch here, we make 8 different perches and are adding 2 more next week. Why so many? Because the perch should be made to fit the axle and the ubolt plate, you shouldn't be made to make it fit! :D
    They are mostly 1/4" thick but we do have 2 Heavy Duty models 3/8" thick!
    Strength, Quality, & Value! Words to live by.....
  2. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    It only makes sense.....
    To buy the ones sized to fit your axle......Why waste time grinding.....
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    PM with pricing shipped to 98110. 14BFF application with 2.5" wide springs.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Do you make them for a 4" axle tube?
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I'm going to say yes since it is here in BOLD. :D
  6. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
    read again... it says 3 widths, and 4 axle diameters... :doah:
  7. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Been a long day away from the computer.......
    All of it spent in the shop......
    Anyway, let me clear up a few things and answer a couple of questions.
    First off we use the USPS Falt Rate boxes whenever possible so shipping on these is 9.45 and we can fit a bunch more in the box too.
    All of our perches are $28 and we only take orders from our website, can't even begin to keep up with orders from PM's.
    We actually make them for 5 axle diameters but 4" is not one of them, we make 3 3/8", 3 1/4", 3", 2 3/4", & 2 1/2". Sorry about the 4", we just can't make them for a fair price in the low quantities the 4" demand.
    I think that answers them all, any more I might answer?
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    D'oh, guess my age is catching up to me or i'm going blind. :doah:
  9. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Age.....
    I like to think "I'm old and fat but at least I'm bald!"
  10. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    To use the right ones and not have to make do......
  11. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Check out the D60/14 Bolt perch
    Kind of cool way to do it....
  12. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    And it works too!
    Check for these as part of the Axle Simple Swap kits!
  13. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    Any chance I can get these with a little extra height so i can ditch the zero rates?
    Thx
  14. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    I have thought of making a series that are taller.....
    But it is a pretty big commitment, the way we make these (2-300 pair at a time) is the only way to make them affordable. The cost of making just a few is too high. How high would you guys like them? They are 7/8" off the axle to the spring mounting surface now.
  15. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I'll measure the height I'm at now with the zero rate on there tonight, but about 1" maybe 1 1/4" taller.
    I understand about needing to make them in quantity, maybe if some others are interested as well??
    I need to replace mine and would like to go with the longer perches to help the wrap a little, but with a zero rate on there it won't really help much, unless i get longer zero rate as well, hmmm...
    thx
  16. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Perches are only needed if you don't......
    Like Link Suspensions!
  17. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Wow talk about fast service I just ordered them thursday and they should up today!! My only question is why is the center pin hole so large? I thought it needed to fit snug?
  18. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    The hole should be 17/32"
    Do you have something different? When we started making these we made them 5/8" which was a misstake, long ago we changed them to 17/32" so they could fit over a standard 1/2" pin with 1/64" room. We sold all of the larger hole perches to 1 customer, or so I thought.....
  19. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    They are definately 5/8" holes
  20. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    I will replace them for you.....
    They have been 17/32" since the second batch.
