Spring Perches on 14 Bolt FF's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Sep 11, 2000.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Spring Perches on 14 Bolt FF\'s
    I've found potential 14 bolt/Dana 44 donors to replace my Corp. 10 bolts. I just want to make sure everything matches up with no problems. One concern was the spring perch spacing. What years and models are compatible with an 85? Thanks.
    Rod
    BLAZE IT UP!!!
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Re: Spring Perches on 14 Bolt FF\'s
    Any 3/4 ton rear up to 88 should fit, the one tons had them closer together, at least some one tons, but if both front and rear came out of the same truck you'll be fine.
    RaisedK5
    "Friends don't let friends drive Fords"
  3. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    What is the oldest year that would fit?
    BLAZE IT UP!!!
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    '73 is the oldest. I think that was the first year for the 14 bolt? Older trucks (3/4 or 1 ton) had either a Dana 60 rear, or the old Eaton drop out style. The spring spacing is different on pre-'73s also.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Just take a tape measure and measure. I think you need them to be about 40" apart, while the 1tons ones are 42.
  6. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I HAVE A 74 BLAZER WITH 3/4 TON DANA 44 AND 14 BOLT REAR AND IT BOLTED RIGHT UP. YOU WILL HAVE NO PROBLEMS PUTTING THOSE AXLES IN YOUR K5.
    DAZED AND CONFUSED IN A 74 BLAZER
    ZEPPLIN
  7. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Thanks guys... that should narrow down my search
    BLAZE IT UP!!!
