Spring plates for a D60 rear?
Discussion in 'The Garage' started by jms, Apr 16, 2003.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    I have a '70 Chevy D60 rear waiting to replace the 10-bolt in my Jimmy. Trouble is, I dont have the spring plates for the axle. Local suspension shop sez they can make the U-bolts, but no idea on the spring plates, probably dealer item. First try with dealer was unproductive. Does anybody have an idea where I might be able to get spring plates?
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    any fabricator could make you a set... its just a steel plate with 5 holes in it...
    j
  3. jms
    Jan 24, 2001
    1,683
    Isn't it stamped steel to resist bend/flex?
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    ORD has them.
  5. jms
    Jan 24, 2001
    1,683
    Thanks for the info, gotta go back and measure the axle diameter one more time before I order.
  6. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    I replaced my 12 bolt with a 60 not too long ago.....out went the 2peice 12bolt (nice broken diff housing) and in went the 60, same u-bolts, same plates, everything.
    -Scott
