spring plates
Discussion in 'The Garage' started by 69K5, Nov 12, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    what can i make spring plates out of? i am ready to put the eaton onder the rear end and the plates are for the bottom of the axle. i would reuse them but they are completely curved unlike the ones of my 12 bolt that are flat on the bottom. how thick should theses be? i already had the u bolts made. they are 3 3/8 for any one else that needs to know. and how far apart are the whole on the flange of a 14ff for disc brake brackets? (center to center
    thanks
    69k5
  2. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    I would go to a driveline or axle shop and buy new perches if thats what you are talking about. if its spring plates that your u-bolts go through I build mine out of 1/2" steel plate so I know it wont ever fail or bend.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Iif its spring plates that your u-bolts go through I build mine out of 1/2" steel plate so I know it wont ever fail or bend.
    thats what it was. i have some 3/8 i was thinking about doubling. i wasnt sure about just one layer. /forums/images/graemlins/thumb.gif
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I believe the Eaton and 14FF have the same axle tube dia. So you should be able to use stock spring plates from a 3/4 ton 14FF without any trouble.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    True on all that info and one more good info for a future upgrade: 14FF rear disc brake brackets can also be used on the Eaton rearends, too. Yep, the Eaton will accept the rear disc kits exactly like the 14FF's do. /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    great !! thats what i thought just wanted to make sure /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    if you want to save the trouble I just bought some spring perches from shakerbuilt for $15 when some other places were asking $45 for the same thing.
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    1 more thing to the mix
    it is very rare but have seen the home mabe flate plates mess up the ubolts
    the stock 14 plates would be a better choice in my opion as they make that ridge - curves 4 a reason its called tourque absorbation
    just my $.02 worth
    Randy
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    LKJR
    im getting spring plates for on top of the springs not the perches. ahakerbuilt id the guiy that hgas those disc conversions right.
    Doc
    I am looking for some stock ones. i wanted to just use the eaton ones but the whole thing is curved and no flat spots on either side. so i will probably just find some from a jy or someone here.
  10. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    one of the converstions yea
